Hi guys,
My car was tuned on injection time (firmware v 1.06) previously). I changed cams+injectors+other mods including aem twin-fire n cop system.Now i am having problem that the engine RPM shoots up to 3000-4000 rpm once its started.
I've put all the values in correctly n used the default v1.09 map wit the same firmware.
ENGINE SIZE = 1900cc
INJECTOR FLOW RATE = 1250cc
Dead time table = according to FIC spec sheet
The problem is that it ran n idled fine with d old map v1.06 even though i didnt touch anything but turned off all correction tables.Where should i start adjusting..? I really hope i could tune with VE for my current setup.
Setup:
Mitsu 4g93 Turbo engine
272 cams
fIc bluemax 1250
Aem 5 bar map
haltech IAT sensor
Please help
I didn't find the right solution from the internet.
References:
http://forums.haltech.com/viewtopic.php?t=9950
Blockchain Marketing Video
Thanks
issues converting to new firmware & VE tuning
